Aug 16th, 2024, 5:10am
LNA and mixer design (Read 2625 times)
rittu
May 05th, 2004, 10:01am
I am designing a CMOS receiver circuit. I have a few doubts regarding the LNA and mixer design.
1. In LNA design usually the cascode transistor's width is kept equal to the main transistor's width. this is done so that the source of the cascode transistor and the drain of the main transistor can be merged into one, which reduces the noise of the cascode transistor due to its source to substrate capacitance. Also we use fingering to reduce the effect of gate resistance. If we use fingering then we cannot merge the source of the cascode transistor with the drain of the main transistor and the reason for which we make the two widths same is no longer valid. In such a situation how do we determine the width of the cascode transistor so that the noise figure is kept minimum and gain is high.
2. Are there any good links to the design of double balanced gilbert cell mixer. Most of the papers that I could find give only the working and not the designing of the mixer.
Thanks for your help
Rittu
fab_jor
Brasil
Re: LNA and mixer design
Reply #1 - Feb 9th, 2006, 11:07pm
PLease, refer to http://www.rfic.uk.co
Regards.
Fabrício
View Profile fab_jor   IP Logged
