Jul 18th, 2024, 11:19pm
freq and bias dependent noise sources (Read 7582 times)
Jess Chen
California Bay Area
May 12th, 2004, 4:36pm
In Spectre, I can specify the frequency dependence of a general noise source using either a file or direct point-by-point entry. Does anyone know if I can make that source depend on an operating point variable too, like a bias current?
Frank Wiedmann
Munich, Germany
Re: freq and bias dependent noise sources
Reply #1 - May 13th, 2004, 2:44am
You could use the multiplier from the ahdlLib for this purpose. Simply connect the noise source to one input terminal and a voltage- or current-controlled voltage source that senses the desired quantity to the other. You might want to modify the multiplier code in order to obain a floating noise voltage or a noise current at the output.
Jess Chen
California Bay Area
Reply #2 - May 13th, 2004, 8:43am
Thanks for the response. From your answer, I assume there is no single Spectre primitive or VerilogA/AMS enhancement that applies here. I just wanted to check for a direct solution before diving in. Thanks again.
Reply #3 - May 13th, 2004, 10:56am
Hi Jess,
You might be able to do it with a combination of vsource and bsource? (I've not tried, but it _ought_ to work).
Or you could use Verilog-A - but then you know that  ;D
Jess Chen
California Bay Area
Reply #4 - May 13th, 2004, 11:40am
Hi Andrew,
Good to hear from you. Thanks for the response. Just to be sure I understood it, by vsource and bsource you are referring to voltage and behavioral sources? In particular, polynomial sources?
I am contemplating using polynomial sources just to make it easier for non-VerilogA speaking engineers to use.
              -Jess
Reply #5 - May 13th, 2004, 3:18pm
Jess,
By bsource, I mean spectre's Behavioural source component, which was released (officially) in IC5033. It's there in some earlier subversions, but is hidden from spectre -h.
It can be used to model arbitrary expressions of voltage and current of other signals, so in this respect it is more flexible than a polynomial controlled source (which might be what you're referring to?).
See "spectre -h bsource" for more details.
In practice it uses Verilog-A internally, but uses the compiled Verilog-A mode which is coming fully in IC5141 (where Verilog-A compiles to a shared library). So the performance is pretty good! And for simple complex expressions (if you get my oxymoron) it's a handy way of implementing things without the need to go as far as using Verilog-A.
Here's some examples from the help:
 Voltage and Current (Sinewave) Source
	   vsrc (n1 n2) bsource v=10.0*sin(2*pi*freq*$time)
	   isrc (n1 n2) bsource i=1.0e-3*sin(2*pi*freq*$time)
 Current controlled current source
	   vsrc (n1 n2) vsource v=10
	   cccs1 (n3 n4) bsource i=gain*i("vsrc:0")
 Current controlled voltage source
	   ccvs1 (n3 n4) bsource v=100*i("vsrc:0")
 Voltage controlled voltage source
	   vsrc (n1 n2) resistor r=100k
	   vcvs1 (n3 n4) bsource v=gain*v(n1,n2)
You can have the bsource represent resistors, capacitors, inductors as well.
Cheers,
Jess Chen
California Bay Area
Reply #6 - May 13th, 2004, 4:48pm
Excellent! I did not know about the bsources and I think they will do the trick. I'll check them out. Thanks Andrew.
             -Jess
