Jul 23rd, 2024, 7:10am
adjust ADE sessions' sizes (Read 2362 times)
Jimmy Li
Guest
Jun 05th, 2004, 10:43am
I found I couldn't enlarge the sessions of the ADC window. Sometime I want the "design variables" session to be larger so that I can the full name of some variables if their names are pretty long.
I can drag the corner of the ADE window to make the whole window large, but each session's size are not changed.
Could any of you kindly tell me how to do this?
Thank you so much,
jimmy li
  IP Logged
Re: adjust ADE sessions' sizes
Reply #1 - Jun 5th, 2004, 11:33pm
You can't. I have an enhancement request in asking for this (it should be possible as DFII forms can have information attached to allow them to be resizable).
However, it's not been implemented yet as it is a reasonable amount of work to do. I suggest you contact Cadence via your normal support channel as this will add more weight to the request to get this done.  The PCR number you might want to reference is 280600.
