Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 22
nd
, 2024, 7:31pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› How to calculate SNR in Hspice or Spectre?
Previous topic
Next topic
How to calculate SNR in Hspice or Spectre? (Read 3937 times)
sch
Jun 13
th
, 2004, 10:35pm
I am runing a DAC circuit using the FFT command in Hspice.Did anyone know how to calculate the SNR in Hspice ?Have any difference to calculate the DAC SNR by Hspice and Matlab?
IP Logged
Spice_Oracle
Re: How to calculate SNR in Hspice or Spectre?
Reply #1 -
Jun 22
nd
, 2004, 10:07am
Try setting
.option fftout
This will print the THD, SNR and SFDF. It will also cause HSPICE to sort the harmonics of the fundamental by size.
IP Logged
weiliang
Reply #2 -
Jun 27
th
, 2004, 11:53pm
For Spectre, you can use PSS to find the signal voltage and use PNOISE to find the noise voltage. Then, use user-defined equation of Calculator to access the result.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
