Aug 14th, 2024, 4:58pm
Programmable Resistor (Read 5568 times)
kayathi
Jun 14th, 2004, 12:22am
Hi All
I am trying a model a programmable resistor.
once certain  conditions are satisfied the resistor's value is changed. i am able to notice the change in resistance
if i apply a CONSTANT CURRENT(the voltage across it seems to increase or decrease as is expected). But, if i apply a CONSTANT VOLTAGE before and after programming the current that flows seems to remain constant.
Is there anyother way to model a resistor other than
V(X,Y) <+ res*I(X,Y);
I don't know whats going on
can somebody shed some light on it
Re: Programmable Resistor
Reply #1 - Jun 14th, 2004, 9:08am
It might be useful if you posted your model so that we can identify what is wrong with it (and what you're trying to do).
kayathi
Reply #2 - Jun 14th, 2004, 1:33pm
Hi Andrew
pasted below is the veriloga model
As u see there are 4 terminals.
When the current through the terminals (inp,inn) is >27mA or <27mA
and the current through (outp,outn) is between 3.6mA and 4.4.mA
the resistance increases or decreases and the that state is held until the next
event.
I want to see this resistance change ONLY when i send a current
-16.5mA<I(inp,inn)<-13.5mA.
When i take two of these and change the state of only one of them and
send same currents through both of them there is a voltage difference. But
when i change the state of one of them and apply the same voltage for both of them
the currents flowing through both of them is same and is equal to the current that would flow
if there were no change of state (as opposed to having different currents as one would expect because of difference in resistances)
I hope this would make my problem clear
See if this helps
Kayathi
`include "constants.h"
`include "discipline.h"
module spinres2(inp,inn,outp,outn);
inout inp,inn,outp,outn;
electrical inp,inn,outp,outn;
real res;
real res_1 ;
real res_0 ;
parameter real cellres = 80 from (1:inf);
parameter real GMR_change = 3 from (1:inf);
analog begin
     res_1 = cellres + ((GMR_change/100) * (cellres));
     res_0 = cellres - ((GMR_change/100) * (cellres));
     begin
           @(cross ((I(inp,inn)-27m))) begin
           if ((I(outp,outn) >= 3.6m) && (I(outp,outn) <= 4.4m))
           res = res_1;
           else res = res;
           @(cross ((I(inn,inp)-27m))) begin
           res = res_0;
           else res = res;
     if ((I(inp,inn) <= -13.5m) && (I(inp,inn) >= -16.5m) && (I(outp,outn) >= 1m) && (I(outp,outn) <= 3m))
     V(outp,outn) <+ res*I(outp,outn);
     else V(outp,outn) <+ cellres * I(outp,outn);
Eugene
Reply #3 - Jun 14th, 2004, 8:04pm
It seems to me that the @cross statements are ambiguous because they do not include any direction options and trigger off similar expressions. If you don't specify the crossing direction (pos to neg or neg to pos), the event will trigger when the argument crosses in either direction. Thus, if +x crosses zero from positive to negative, -x will cross from negative to positive. Without a directional option, both will trigger. I think you should check the signs of your 27ma arguments and/or consider adding directions for triggering the event.
Reply #4 - Jun 15th, 2004, 10:18am
In addition to Eugene's points about cross, there is something rather suspect about the logic in your code.
In order to change the value of "res", the current flowing through the resistor has to be between 3.6mA and 4.4mA.
However, you have an if out the resistor itself, which means that it has a constant value resistor unless the current is between 1mA and 3mA. You're going to have all sorts of discontinuous (and rather strange) behaviour at the very least.
For debugging, I removed the final if, and put a $debug statement in to look at the values - see below. I'm sure that if you do this and think carefully about what you're doing you can get it to do what you want (whatever that might be!).
real res;
real res_1 ;
real res_0 ;
analog begin
 begin
  res = res_1;
  else res = res;
  res = res_0;
  else res = res;
 $debug("res is %g, I(inp,inn) is %g,res_1 is %g, res_0 is %g\n",res,I(inp,inn),res_1, res_0);
// if ((I(inp,inn) <= -13.5m) && (I(inp,inn) >= -16.5m) && (I(outp,outn) >= 1m) && (I(outp,outn) <= 3m))
// else V(outp,outn) <+ cellres * I(outp,outn);
By the way, here's the little netlist I used for testing the above:
r1 (1 0 2 0) spinres2
i2 (2 0) isource dc=-4m
i1 (1 0) isource type=sine ampl=30m freq=1M
ahdl_include "desguide.va"
tran tran stop=1u
