Aug 14th, 2024, 3:00pm
Lower transistor Length -> Lower Vth ?? (Read 5445 times)
wccheng
Jun 15th, 2004, 8:55am
Dear all,
     Is lower transistor length will give out lower threshold voltage? Actually, my supervisor said that it is not correct. Could anyone explain to me? Actually, I just know that smaller transistor length will give out smaller parasitic capacitor in order to give out higher Ft frequency.
wccheng
sachin
Guest
Re: Lower transistor Length -> Lower Vth ??
Reply #1 - Jun 29th, 2004, 6:24am
Actually that depends upon the technology you are using. I mean if you decrease channel length by changing the technology then vth will increased. For same technology output resistance will increased, no effect on vth. Is this answer you are expecting?
sachin
  IP Logged
Shiva
Guest
Reply #2 - Aug 1st, 2004, 12:32pm
for a given technology the VT of a transistor will DECREASE for decreasing L, so your teacher's wrong.
This can be easily understood by an intuitive reasoning:
a smaller L, means a smaller capacitor (W*L) so less charge is needed to charge this capacitor (which is the MOS channel).
This corresponds to a lowering of the VT of the transistor, which corresponds to the minimal gate voltage to build up enough charge in the channel.
Kind Regards
  IP Logged
terryssw
Reply #3 - Oct 3rd, 2004, 7:26am
The voltage needed to charge the gate in order to inverse the channel is independent to the capacitance needed to charge, it depends actually on the capacitance per unit area. Actually Vth will have little changes (several tens mVs) with L, but depends on technology and biasing conditions, it can either increase or decrease. But the change surely is not related to length by the amount of capacitance.
chen
Reply #4 - Oct 14th, 2004, 5:25pm
I am not specialised in device physics so correct me if I am wrong. But I heard that as L drops, Vth also drops. However, a small Vth would mean large leakage current (current when VGS=0). Hence, tox is decreased in proportion also to maintain the Vth. However, the general trend is that Vth is still decreasing slowly.
Teddy
Reply #5 - Dec 9th, 2004, 11:38am
it's probably too late now but VTh modulation due to L change is caused by second order effects. Try to look for them. Also try to look for DIBL - drain induced barrier lowering.
For most of time you would have hard time to see it in sims. Vth is usualy part of model params and is not changing - depends on level of your model. Look at BSIM 4.
For design you should consider Vth as fixed value.
