Jul 20th, 2024, 5:22am
L effect on mismatch (Read 5754 times)
modern_analog
Jul 07th, 2004, 4:33pm
This might sound very basic but here goes
The mismatch depends on WL, or more accurately 1/sqrt(WL). Then why do we need large L. It seems we can get away with small L and large W.
Edward
Re: L effect on mismatch
Reply #1 - Jul 16th, 2004, 10:57am
sometimes, in order to get the desired gain, we use larger L.
then, about mismatch, the larger the transistor is, the smaller the mismatch percentage.
Humungus
Reply #2 - Aug 24th, 2004, 5:52am
Also, L longer than minimum reduces leakage current. For both W and L greater than minumim values, the etch effect is smaller than when minimum values are used
analognut
Reply #3 - Sep 12th, 2004, 6:14pm
First , to minimize errors due to the side-diffusion of the source and drain areas (Ld)
Second, to minmize errors due to the threshold voltage of short-channel devices which exhibits some dependence on the channel length.
above lines are quoted from the book written by razavi
Raul
San Jose, CA.
Reply #4 - Mar 19th, 2006, 9:22pm
mismatch also depends on Vgst(Vgs-Vt). Large W and small L will give you a low Vgst which will give you a high gm and the error voltage at the gate of the transistor is multiplied by the gm of the transistor to give the error drain current. Therefore you want to have a large Vgst in order to get a low gm so that the error is multiplied by a smaller number.
bottomline, mismatch has two components; one is size and the other is bias point(gm/Vgst).
regards, Raul Perez
RobG
Bozeman, MT
Reply #5 - Mar 20th, 2006, 5:05pm
Expanding on what Raul said... if you do the analysis for a current mirror in strong inversion you will find that the mismatch [of the current, (edit)] is actually independent of width.  This is because the Gm of the transistor is increasing as sqrt(W) just as the Vt mismatch is decreasing by sqrt(W).  Since the current error dI/I is gm*dVt the effects cancel.  So, for a mirror, you want to use as long a channel as speed (and headroom) will allow.
On the other hand, if you have a diff pair (like an opamp diff pair), you generally want to make it as wide as is practical (keeping W*L constant) so that the Gm is as large as possible.  This doesn't change the diff pair's contribution, but it decreases the contribution of the mirror because the diff pair mismatch is multiplied by Gm(diff)/Gm(mirror).
So... sometime you want it long, some times you don't.  The same analysis holds for 1/f noise...
rg
« Last Edit: Mar 20th, 2006, 6:28pm by RobG »
Reply #6 - Mar 22nd, 2006, 4:33am
Modern_analog,
  You might also want to read some papers in addition to
Pelgrom's,
"Understanding MOSFET Mismatch for Analog Design",
P. Drennan and C. McAndrew, JSSC, March 2003
"Measurement and Modeling of MOS Transistor Current
Mismatch in Analog IC’s", E. Felt, et al, ICCAD, 1994
The issue of mismatch modeling is complex than mismatch
is proportional to sqrt(W*L), as Rob mentions you also need
to consider the operating point.
This is certainly a useful rule of thumb for designers to keep
in mind. However, it includes some assumptions that designers
need to understand and they should not blindly extrapolate
based on it.
