Aug 15th, 2024, 2:24pm
Order of execution at a timestep in Verilog (Read 2079 times)
sutapanaki
Aug 15th, 2004, 12:50pm
I need some help with the following Verilog code. If someone understands this, please respond. My question is about the order of execution during one time step.
In the code I have it goes like this:
1: always
2: begin
3: #50 clk <= 1'b0;
4: #50 clk <= 1'b1;
$display($time, "clk%b", clk) ;
//here clk will be clk == 1'b0 because of the non blocking assignment
5: end
6: always @(posedge clk)
7: begin
/*I expected different behavior here: I expect clk == 1'b0. As it is above. That is what I expect from a non blocking assignment when the timestep (100) has not finished yet. The simulation shows clk == 1'b1. So the non blocking assignment is executed not at the end of the time step but somewhere in the midle - before the event it trigers. This surprises me*/
8: if(clk === 1'b1)
9: clk1 <= clk;
10: end
« Last Edit: Aug 15th, 2004, 7:39pm by sutapanaki »
