Nov 7th, 2026, 9:16pm
How to design a Latch? (Read 4999 times)
cyjim
Aug 22nd, 2004, 5:09pm
Hi,all!
I've been in trouble with my design for days,I have to ask for ur help now.
I'd like to design a Latch,which works as below:
D(7 downto 0) is the input of the Latch,while  A(7 downto 0) ,B(7 downto 0) ,E(7 downto 0)  and F(7 downto 0) are the four outputs of the Latch.Ctr(1 downto 0) is the control variable. When Ctr="00","01","10"and "11", input D was sent to output A,B,E and F respectively.
My design tool is Quartus II,I hope you can give me some advices or opinions.
I'm eager to hear from you,Thanks a lot!
pktan
Guest
Re: How to design a Latch?
Reply #1 - Jan 19th, 2005, 12:52am
Try This.
library ieee;
use ieee.std_logic_1164.all;
entity test is port(
D : IN std_logic_vector(7 downto 0);
Ctr : IN std_logic_vector(1 downto 0);
A : OUT std_logic_vector(7 downto 0);
B : OUT std_logic_vector(7 downto 0);
E : OUT std_logic_vector(7 downto 0);
F : OUT std_logic_vector(7 downto 0)
end;
architecture behave of test is
begin
PROCESS(Ctr)
BEGIN
if(Ctr = "00") then
     A <= D;
elsif(Ctr="01") then
     B<= D;
elsif(Ctr="10") then
     E<= D;
elsif(Ctr="11") then
     F<= D;
end if;
END PROCESS;
end behave;
  IP Logged
Nisha
Guest
Reply #2 - Jan 27th, 2005, 9:24pm
Hi!
the code above will not synthesise a latch.. this is just a basic demux.. or decoder.
If you need a latch, you have to put this inside a process and trigger it with a clock'event and edge.
library ieee;
Clk:in std_logic;
end;
begin
PROCESS(Clk)
BEGIN
if clk'event and clk= '1' then -- positive edge triggered
if(Ctr = "00") then
A <= D;
B<= D;
E<= D;
F<= D;
end if;
end if;
END PROCESS;
end behave;
The absence of the elsif condition in the clk leads to a latch.
Also remember that if leads to implied priority...in case that is not desired use a 'case' statement.
  IP Logged
Paul
Switzerland
Reply #3 - Jan 28th, 2005, 3:06am
I am certainly not an expert in this domain, but it seemed to me the edge sensitivity would be synthesized as a kind of FF. If you want to get a latch, shouldn't the process be CTR and CLK sensitive, but only sensitive to the level of clock and not the edge? I.e. If clk='1' and the process is triggered by CTR, the value would still be updated. Maybe Nisha can comment on that.
Paul
