Eugene
I am not 100% sure, but as I recall, SpectreRF uses the solution from the last sweep value and as initial conditions for the next sweep value. The idea was that if you had trouble getting convergence at some parameter value, you could "sneak up" on it using a parameter sweep. It seems odd that you see the convergence warnings during the sweep and not on the individual run.
