Aug 15th, 2024, 10:17am
Frequency response for verilog A models (Read 5094 times)
Voldemort
Oct 17th, 2004, 6:14pm
Hi
What is the procedure for obtaining the frequency response of a second order system designed using verilog a. The verilog model I am using is as follows
`include "discipline.h"
`include "constants.h"
//  model strans
//   S-domain in Numerator-Denominator form
//   Filter order is:  1 / 3
module strans (vin, vout) ;
 input vin;
 output vout;
 electrical vin, vout;
//               nxN  is  numerator of degree N.
//               dxN  is  denominator of degree N.
 parameter real nx0 = 1.0;
 parameter real dx0 = 202.2;
 parameter real dx1 = 1.202e5;
 parameter real dx2 = 1.67e-10;
   analog begin
       V(vout) <+  laplace_nd( V(vin), [ nx0 ],
                [ dx0, dx1, dx2 ]);
I created a symbol for this model and I connected a vsin source at the vin node and a 1k resistor at the vout node to ground. I ran an ac simulation in spectre. The ac magnitude I obtain is just some really low constant value (-6.7k).
The system is a second order system with a resonant frequency around 180kHz.
Can someone explain the correct way to do this ?
Thank You
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: Frequency response for verilog A models
Reply #1 - Oct 17th, 2004, 10:20pm
You must specify the AC magnitude of the input source. Using a value of 1 is usually the most convienent.
- MM -
Voldemort
Reply #2 - Oct 18th, 2004, 8:38am
Mighty Mouse,
Thank you for your help/
I did include the AC magnitude and amplitude in my simulation
Here is my netliist.
//Genenerated for: spectre
// Generated on: Oct 18 11:21:25 2004
// Design library name: clloop
// Design cell name: cf_uphone
simulator lang=spectre
global 0
// Library name: clloop
// Cell name: cf_uphone
// View name: schematic
V0 (net3 0) vsource type=sine mag=1 ampl=1 freq=1K
R0 (net6 0) resistor r=1K m=1
I0 (net3 net6) strans nx0=10000 dx0=1 dx1=100 dx2=10000
   digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
   sensfile="../psf/sens.output"
ac ac start=1 stop=1G annotate=status
ahdl_include "/home/users/2/xxxxxx/clloop/uphonel/veriloga/veriloga.va"
I did change the parameters of my second order system to a simpler one in this. The system has a gain of 1, with a resonant frequency at 100Hz and a damping ratio of 0.5
Voldemort
Reply #3 - Oct 18th, 2004, 11:57am
Hi
I figured out the problem. It was my model Sad
I had my s domain coefficients reversed and another mistake I made was that the s domain coef are in radians and not in Hz. Hence the screw up.
Thanks for your reply mighty mouse
