Oct 4th, 2026, 10:02am
signal updating (Read 1163 times)
Mark Burford
Guest
signal updating
Oct 19th, 2004, 7:25am
I want to have a signal that updates from the quantity v across i through p1 to p2.
I have a process running also that I want the quantity in the sensitivity list, this is not allowed so I declared a signal ...
signal v_last : real;
v_last <= v;
v_last only seems to update once, no matter where I put the statement.
I want it to follow v.
Any ideas?
Mark
  IP Logged
Paul
Switzerland
Re: signal updating
Reply #1 - Oct 27th, 2004, 8:09am
Hi Mark,
I had to convert an analog signal into a digital one. I used a process sensitive to ana_sig'above(vth) in which I affected dig_sig to either '0' or '1'... I don't know if there is a more elegant way to do this, in case I am interested to learn.
In your case, you may try to write a process sensitive to
ana_sig'above(vth)
where vth is ana_sig(k-1)+ana_step
and ana_step will define your vertical tracking resolution (and so your simulation time).
Let me know if this works, I didn't try it.
Paul
Mark Burford
Guest
Re: signal updating
Reply #2 - Feb 14th, 2005, 10:22am
Hi Paul, thanks for feedback ages ago, I soved the problem, see code below:
;D
threshold <= not vs'above(v_last-delta_v) or vs'above(v_last+delta_v);
fdr_p1 : process (threshold) is
my process code
end process
v == expression dependant on stuff in process.
It allows good resolution and accuracy control.  Ihad actually figured this before reading your response just now ages back.gtrea minds and all that!
Mark
  IP Logged
