Oct 18th, 2026, 5:17am
Verilog-A model for VCO (Read 1983 times)
Rohan Batra
Guest
Nov 02nd, 2004, 11:19pm
I am trying to write a verilog-A model for a VCO. But instead of the voltage out vs voltage in relationship, I want to model a frequency out vs voltage in relationship. Is there anyway to describe the output as a "frequency" discipline type. I know that you can declare something as a "voltage" or "phase" in verilog-A.
  IP Logged
Re: Verilog-A model for VCO
Reply #1 - Dec 28th, 2004, 4:46pm
Rohan,
  Do it all the time, but I have always just output the
frequency as a voltage. Never actually seen anyone
create a separate discipline to do this. Have you tried
defining a new discipline for frequency in the discipline.vams,
(for Spectre) file? If you update the file you file, you need
to point to the correct one in module.
                                                          Art Schaldenbrand
Eugene
Reply #2 - Jan 2nd, 2005, 9:51pm
I also usually just represent frequency with a voltaqe. The trick is to choose the right frequency units (GHz, MHz, etc.) to keep numbers reasonable. I use voltage primarily because that node is a convenient place to insert a zero-voltage DC voltage source, with AC magnitude=1, to compute loop gain. I think you will have to create a Verilog A module for this source if you use a frequency discipline. However, if you use voltage, you can use the Spectre primitive. Another reason I usually choose the electrical discipline is that, being an electrical engineer, it is often easier for me to introduce filters using RLCs instead of creating another verilogA block for a Laplace transform. I also wonder if the simulation runs faster with primitives instead of Laplace blocks.
gogomi
Reply #3 - Feb 28th, 2005, 9:42pm
Just wondering if you use voltage to represent frequency, then how do you model the phase?
Do you also use voltage?
gogomi
