Mar 5th, 2026, 7:08pm
Error on calculating the phase difference (Read 2259 times)
Jason Dai
Guest
Nov 05th, 2004, 6:29pm
I'm doing a digital PLL behavior model, need calculate the integrated phase difference of reference clock and divided down VCO feedback clock at every rising edge of reference clock, the code is below:
@(cross(V(refclk)-1.25, 1, ttol)) begin
    state = state +1;
    phasediff = 2 * `M_PI *( state + ($abstime - tfb1)/(tfb1 - tfb0));
@(cross(V(fbclk)-1.25, 1, ttol)) begin
   state = state -1;
   tfb0 = tfb1;
   tfb1 = $abstime;
Simulation shows when the two clocks' rising edge occur at exactly same time, the phase error calculation will go wrong. the reason sounds like the calculation can not be done when the variable it used( state, tfb0, tfb1) changing.
Do somebody have same experience and how to solve it?
Thanks a lot !
Jason
  IP Logged
