sutapanaki
I've been recently looking at the simInfo sections of some primitives - transistors, resistors, etc. I noticed that there is a netlisting procedure which somehow links the primitive with the chosen simulator and is used for netlisting a circuit. Can someone explain how this works and more importantly where this procedure can be found? I assume it is a file somewhere, probably a SKILL script. Thanks in advance.
