Aug 16th, 2024, 5:29pm
Convergence of PSS with "writefinal", &q (Read 922 times)
mgehring
Portland, OR
Nov 18th, 2004, 1:50pm
I am using version 5.0.33.144
I have noticed often that there are convergence difficulties ( especially with large circuits ) when using writepss/readpss or writefinal/readic. I cannot concieve how there can be difficulty when using these with a circuit that is unchanged. I have recently seen, on a small circuit, PSS not converge when loading a "final" state with readic and skipdc=yes ( identical circuit and options ). It had to "use a few more tstab steps" to converge.
Also, I have see with a large circuit that loading a writepss with readpss requires MIC refinement. Again, this makes no sense - why does it not save the refined result ? These refinement steps take as long as the original PSS iterations.
If anyone has a solution to this, please let me know.
Mark
Paul Geraedts
GIGO
Enschede, Netherlands
Re: Convergence of PSS with "writefinal"
Reply #1 - Dec 28th, 2004, 3:01am
Similar experiences here.
In general, writing and reading of the circuit state seems problematic within Cadence (DC, PSS and QPSS).
From theory, it seems a nice way to speed up similar simulations (like in Envelope Analysis).
Maybe somebody from Cadence could shed light on this issue? Thanks in advance!
Paul
Reply #2 - Jan 3rd, 2005, 8:36pm
The issue with readpss doing a MIC always again was resolved in IC5141 from PCR 604941. A new option "checkpss" was also added, which you can set to no to stop it trying to check if the readpss data is consistent or not.
As for writefinal/readic type problems, this unfortunately does  happen sometimes. A true state saving mechanism for transient has been added in the MMSIM60 version of spectre (released a few weeks ago). From spectre -h tran:
Quote:
State-file parameters
12      write             File to which initial transient solution is to be
                         written.
13      writefinal        File to which final transient solution is to be
                         written.
14      ckptperiod        Checkpoint the analysis periodically using the
                         specified period.
15      saveperiod        save the tran analysis periodically on the smulation
                         time.
16      saveclock=1800 s  save the tran analysis periodically on the wall clock
                         time.
17      savetime=[...]    save the analysis states into files on the specified
                         time points.
18      savefile          save the analysis states into the specified file.
19      recover           specify the file to be restored.
(note, it's the options with "save" or "recover" in the name which are new).
I expect it's in the release notes too. However, I just noticed that pss doesn't have similar options, so I don't think it will work (yet) with pss (i.e. if you want to recover a saved state (saved at the end of a transient) as the starting point for a pss); I'll file a PCR for that.
mgehring
Portland, OR
Reply #3 - Jan 5th, 2005, 9:32am
I guess I will have to try this new release. In any case, the bottom line for me is that I should achieve the original final convergence norm(s) when I load a final state ( readic ) or readpss with an identical circuit, without requiring any additional computations. If that is the case, then I aqree this issue has been resolved. Otherwise, one is not really loading the "true" final state.
Thanks, Mark
