Jul 31st, 2024, 5:19pm
PAC result of SC-CMFB not correct (Read 2245 times)
jimmy
Nov 25th, 2004, 2:22pm
I tryied to simulate the gain and banswidth of my folded cascode with SC-CMFB. Nothing is special in my circuit.
The first method I used the way ywguo proposed on the forum, which replace the SC with equivalent resisotors and then AC simulation. I got about 69dB DC gain.
The second method I used is to  use a ideal CMFB composed of VCVS to run AC simulation and I got similar results as that in the first method.
However, when I used PSS and PAC to simulate the circuit, I got only 53dB DC gain. I checked the DC voltages of the differential output, they are about what I want I think the CMFB works.
I have no idea why the DC gain from PAC is so low, hope someone can give me a hand.
I guess it is due to some loading of my CMFB to the opamp. When I inserted a buffer (VCVS) between my opamp output and CMFB, I could get 69dB with PAC simulation. So how can I get around this problem? I use only 100f and 200f Caps in my CMFB. They are pretty small, aren't they?
Btw, how can I check DC operating points, such as gm, working region, etc. after running PSS analysis.
thanks a lot,
jimmy
« Last Edit: Nov 25th, 2004, 6:24pm by jimmy »
sissi
Re: PAC result of SC-CMFB not correct
Reply #1 - May 7th, 2012, 12:43am
I have the same question,some can explain this?thx
View Profile sissi   IP Logged
