jimmy
I have been runing mixed signal simulation using spectreVerilog for a while. I want to use command line to do this job but I couldn't figure out how to do it. I can run spectre simulation from command line pretty easily. But when I tried to run spectreVerilog from command line, I could never make it work, even though I use the generated command from cadence itself after I clicked "run" in ADE.
Can anyone tell me how to do this?
thanks a lot, jimmy
