crhu
![](https://designers-guide.org/forum/avatars/charlie_brown.gif)
I come, I see, and I go
Hi, heaton, What region does your transistor work? You need to make sure that the transistor works at staturation/pinch off region.
Vdsat, (aka veff (effective voltage) and delta v), is used to check if the transistor works at saturation.
Vdsat is calculated with Ids and w/l, sqrt((2*Ids)/(kp*w/l)). You can derive it from the saturaton current equation w/o channel length modulation: Ids = kp/2*(w/l)*(Vgs-vth)^2 Vdsat = vgs -vth @ saturation
If vgs > vth, and vds > vdsat, the transistor is in saturation. In this case, vdsat=vgs-vth if channel length modulation is omitted. If vgs > vth, and vds < vdsat, in linear region. In this case, vdsat != vgs-vth, because in linear region there is no square law bt. Ids and (Vgs-vth).
