chlai
Save the earth~
Taipei, Taiwan
Hello Andrew, Thank you very much for answering me so many questions.
Because idtmod() means to integrate the peridic signal and noise in one cycle (of period), which also means to make all input noise become cyclostationary noise.
My problem is: Can we determine all input noise (including flicker noise, white noise) become cyclic in this vco model. If the answer is no, would the vco model generate error phase noise analysis result? I think this is a cyclostationary noise definition question. Sorry to confuse you.
Thank you very much for your kindly interested. Sincerely yours, Daniel Lai
