Apr 29th, 2024, 6:32am
Array size function in Verilog-A/AMS? (Read 2802 times)
mmirmak
Intel signal
integrity; chair,
IBIS Open Forum
Folsom, CA
Dec 03rd, 2004, 11:04pm
I have a simple question regarding determining the size of arrays in Verilog-A and Verilog-AMS.
If I have a function which will accept, for example, an array of reals, how may I determine within the function the size of the array?  In other words, do I have to pass the array size into my function as an explicit integer variable?  Is there some "sizeof" function in Verilog-A or Verilog-AMS which would allow me to determine the size of the array a priori?
Thanks!
- Michael Mirmak
Intel Corp.
Chair, EIA/IBIS Open Forum
Re: Array size function in Verilog-A/AMS?
Reply #1 - Jun 6th, 2005, 8:53am
I'm not aware of a way to determine the array size.
Since in Verilog (1364), arrays have to be declared using constant_expressions for the address ranges, it seems that one wouldn't need to query the array (it can't grow during the simulation), other than to avoid passing an additional argument.
