Razer
Guest
Hi, I extracted n and fc parameters of PFD/CP for the phase domain model by driving the PFD/CP with representative periodic signals with a phase difference as explained in section 5 of PLLnoise+jitter paper. I get lower values of 'n' when I drive the PFD/CP with lower phase difference between the representative periodic inputs. 1. which of value of 'n' should I be using in the code of Listing 6. ? 2. I use Icpmax as the 'gain' parameter for Listing 6.?
Thanks Razer
