Jul 16th, 2024, 10:27pm
Parameterizable models in V-AMS (Read 1957 times)
Vikram Srinivasan
Guest
Dec 26th, 2004, 5:21pm
Can somebody tell me how one can make models in V-AMS parameterizable?As in, when you build circuits in Magic and run them with SPICE,you have the ability to change transistor dimensions to suit your requirements of area/power dissipation/speed etc. What would be the best method to achieve this in V-AMS with the AMS Design Simulator. Specifically, can analog models be made parameterizable?
  IP Logged
wbear
Re: Parameterizable models in V-AMS
Reply #1 - Jan 28th, 2008, 4:20pm
If you are using Spectre, changing the parameters of a VerilogA model is very simple -- just open up the property window of your device, select "VerilogA" in the CDF Parameter of View, and all the parameters defined in your model should pop up.
