Jul 16th, 2024, 10:19pm
mux-64:1 (Read 6685 times)
kamath
mux-64:1
Jul 26th, 2007, 7:40am
hi,
i need to code a 64:1 mux in behavioral level.If i use a case then there would be 64 input and it will be a bulky code.incase a use 4:1(mux code) and instantiate then would there be anyy delay problem.
what would be the efficient way to do this..
thanx
boe
Re: mux-64:1
Reply #1 - Jul 27th, 2007, 1:57am
Hi kamath,
Did you try a bus signal for your inputs?
Hope this helps...
BOE
boe
Re: mux-64:1
Reply #2 - Jul 27th, 2007, 9:12am
Something along the lines of
`include "constants.vams"
`include "disciplines.vams"
module test ( inp, outp, ctrl );
input [63:0] inp;
input [ 5:0] ctrl;
output outp;
electrical [63:0] inp;
electrical outp;
analog begin
 V(outp) <+ V(inp[ctrl]);
It compiles on my system, but I haven't checked what it does...
BOE
Bill Toole
Re: mux-64:1
Reply #3 - Feb 9th, 2008, 12:10pm
Hi
I would like to implement a mux very similar to the code boe suggested for a simulation test bench where i want to set one input for the entire simulation.  So instead of using a control signal i would like to use an integer parameter to select the input of the mux. Here is my code
module 64bit_mux(inp, outp);
input [63:0] inp;
output outp;
electrical outp;
parameter integer N=0 from [0:63];
analog begin
 V(outp) <+ V(inp[N]);
However, it will not compile and i get the error message
Error found by spectre during SpectreHDL compile.
   "/64bit_mux/veriloga/veriloga.va",
       line 16: "V(outp) <+ V(inp[N])<<--? ;"
       line 16: Error: The index used to access bits of analog signal vector
       `inp' is not a constant, constant expression, genvar variable or a
       genvar-constant expression. To avoid this problem, ensure that the
       indexes used to access the bits of analog signal vectors are constants,
       constant expressions, genvar variables or genvar-constant expressions.
I tried using a genvar variable but no luck. Sugestions?
Bill
BTW, I tried the same code as BOE but get the same error message as above
ACWWong
Oxford, UK
Re: mux-64:1
Reply #4 - Feb 9th, 2008, 5:51pm
hi bill,
try using an intermediate variable, so this will work:
input [63:0] inp;
output outp;
electrical outp;
integer in_var[63:0];
integer k;
real out_var;
analog begin
generate k (0,63) begin
  in_var[k] = V(inp[k]);
out_var = in_var[N];
V(outp) = out_var;
cheers
aw
Bill Toole
Re: mux-64:1
Reply #5 - Feb 12th, 2008, 5:02am
Thanks AW, that did the trick
Bill
