Jul 21st, 2024, 3:15pm
Low 1/f noise CMOS amplifier (Read 5422 times)
Jan 09th, 2005, 7:06pm
I need design a CMOS amplifier with low 1/f noise corner. Thermal noise doesn't matter.
Please give me guide or advise some books, papers.
Yawei
Re: Low 1/f noise CMOS amplifier
Reply #1 - Jan 9th, 2005, 8:06pm
You could try a chopper stabilized ampifier or correlated double sampling.
101questions
Reply #2 - Jan 9th, 2005, 11:08pm
Some auto-zeroing techniques suppress 1/f noise as well. In fact diffrences betweel auto-zero, correlated double sampling and chopper stabilizer are somewhat blurry, the concepts are quite similar.
Generally, consider yourself lucky if you manage to improve 1/f noise by a factor of 5 with these techniques.
Other than that use large area devices, avoid pocket implant mos, if you can. Some might recommend to avoid subthreshold devices, while some others might disagree.
There are also black magic techniques, like gated bias, but they are not in the model, so only silicon would tell how they are effective.
Frank Wiedmann
Munich, Germany
Reply #3 - Jan 9th, 2005, 11:35pm
A good overview over auto-zero etc. can be found at http://cmosedu.com/cmos2/designers/Enz%20and%20Temes.pdf.
Raul
San Jose, CA.
Reply #4 - Mar 19th, 2006, 9:14pm
if you don't want to use any of the sampling techniques and just want to get the low 1/f noise by proper choosing of the devices and architecture, you should:
1. Use a classic two-stage amplifier given that it only contains 4 transistors contributing noise.
2. Use natural/un-implanted devices for your input pair. This helps because the implantation process adds damage to the silicon-oxide interface that creates trapping sites for the carriers in the channel.
3. Use buried channel devices for your input pair. 1/f is noise created at the silicon-oxide interface, buried channel devices have the carriers going below this interface therefore less carriers are trapped and released in Si-O interface and less 1/f noise results.
4. Increase the length of the active load devices in the first stage as much as you can and then sweep the length of the input pair devices as you plot input referred noise at a frequency. The curve will look like a bell and there is an optimum minimum point that you should choose.
5. Maximize the Vgst of your active load devices.
6. Operate you input pair devices in the sub-threshold region(low Vgst) to maximize their gm and minimize input referred voltage noise.
regards, Raul Perez
xwcwc1234
TAIWAN
Reply #5 - Apr 18th, 2006, 12:46am
How to simulate noise performance of chopping amplifier ? A chopping amplifier with clock can not be simulated using Hspice . is there other tools can do the AC and Noise simulation ?
Reply #6 - Apr 19th, 2006, 10:59pm
Do you have access to spectreRF? You could use pss/pnoise analyses to investigate the noise of a chopper-stabilized amplifier,
or pss/pac to look at the frequency response.
