I've seen this problem when using spectre's assert statements, and then doing a parametric analysis.
If so, it was fixed as a result of PCR 686439 in subversion 5.0.33.500.1.12
Are you using a subversion before that? (Note, if the subversion only has 5 sets of numbers, it is before that, since the numbering scheme changed to insert an additional digit indicating which USR the ISR is based on).
