Aug 16th, 2024, 5:12am
Hooking up VCO and prescaler (Read 2987 times)
gogomi
Feb 07th, 2005, 10:51am
I am working on a fractional-N PLL design and I am having trouble
with the interface from VCO to prescaler. I used a complementary
LC-VCO in my design, which has a 1/2 Vdd DC bias voltage at
the output, and I used CML latches in the prescaler. If I hook them
up directly, it looks the DC voltage from VCO puts the prescaler
latches on all the time. I don't know if there is a good way to solve
this kind of problem without degrading the performance too much.
Thank you for your help!
gogomi
DReynolds
Scarborough ME
Re: Hooking up VCO and prescaler
Reply #1 - Apr 14th, 2005, 5:59am
Gogomi, I am not sure I understand your problem: what is your vco output swing when you have the latches attached? Worst case, why not ac couple and set your dc level on the latches yourself?
David Reynolds
wued
Reply #2 - Apr 21st, 2005, 10:48pm
  I donot think it is a good way to connected them together directly,why not use a buffer.The buffer may be a CML one,there is not level problem.
