Aug 14th, 2024, 2:56pm
Intermodulation (Read 2209 times)
myjasonlee
Intermodulation
Feb 12th, 2005, 6:36am
Hello Everyone
I wish to clarif with you about the following topics;
If the input signal is coming in with two closely spaced channels, say at ω and
ω + δ, then the third order IM terms of interest are
2 ω - ( ω + δ ) = ω - δ
and
2 ( ω + δ ) - ω = ω + 2δ
My question is, are both of these frequencies important for IM distortion, or is it only the first one, which is nearest to ω that causes problems ?
For multitone input, say N tones, each spaced by δ, so that we have ω, ω + δ,
ω + 2 δ, ω + 3 δ, ..., ω + N δ, we will get many 2 tone and 3 tone IM products
2 (ω + i δ) - ( ω + j δ ) = ω + ( i - j ) δ
and
(ω + i δ) + ( ω + j δ ) - (ω + k δ) = ω + ( i + j - k )δ.
Are the only terms of interest for IM3 the ones where
i - j = ± 1
and
i + j - k = ± 1 ?
Jason and Tel
myjasonlee
Re: Intermodulation
Reply #1 - Feb 12th, 2005, 6:40am
Sorry there are some problems.
Kindly refer to the below corrected question..........
Thank you
Hello Everyone
I wish to clarify with you about the following topics
If the input signal is coming in with two closely spaced channels, say at w  and
w  + delta , then the third order IM terms of interest are
2 w  - ( w  + delta  ) = w  - delta
and
2 ( w  + delta  ) - w  = w  + 2delta
My question is, are both of these frequencies important for IM distortion, or is it only the first one, which is nearest to w  that causes problems ?
For multitone input, say N tones, each spaced by delta , so that we have w , w  + delta ,
w  + 2 delta , w  + 3 delta , ..., w  + N delta , we will get many 2 tone and 3 tone IM products
2 (w  + i delta ) - ( w  + j delta  ) = w  + ( i - j ) delta
and
(w  + i delta ) + ( w  + j delta  ) - (w  + k delta ) = w  + ( i + j - k )delta .
i - j = ± 1
and
i + j - k = ± 1 ?
Jason and Tel
