Hi, Cowell,
You should not expect to get the precise value of (u*Cox) from BSIM model directly. Actually, it varies much beacause the real MOS transistor's behaviour is so complex. Many parameters varies due to temperature, voltage, process, width, length, etc. So it is impossible to get a constant, precise value for all transistors.
BSIM model is a empirical model. It has many parameters that havn't any physical explanation. So you need extract it using SPICE or Spectre simulation. Or you can calculate Id, Rout using the Gm, Gds, and so on listed in the report of an OP simulatioin. But Gm, Gds, etc must differ for transistor with different width, length, or temperature, etc.
Best regards,
Yawei
