May 5th, 2024, 6:47am
generating spectre netlist from command promt. (Read 2777 times)
kamesh419
Feb 21st, 2005, 8:48am
Dear all,
    I have a gate level netlist for an 8-bit adder. I used to import it to cadence and i can simulate it through graphical interface and generate the spectre netlist.
I would like to how i can generate the spectre netlist from command promt. I later modify the netlist to include sources and simulation commands and simulate the changed netlist from command promt as
spectre <file name.scs> (i am interested in automating my stuff).
Thanks and Regards,
Kamesh.
Truth lies everywhere and partially even with the error.
Re: generating spectre netlist from command promt.
Reply #1 - Feb 21st, 2005, 11:50am
Put this in a file:
simulator('spectre)
design("mylib" "mycell" "myview")
createNetlist(?display nil)
exit()
And then do:
icms -restore aboveScript.ocn -nograph
