Jul 19th, 2024, 5:23pm
Noise Reductin in Gm-C Low-Pass Filter (Read 1552 times)
nicole
Mar 07th, 2005, 6:49pm
Dear all,
    These days I am doing the Gm-C LPF design, the spec is as following: center frequency=133KHz, BW=233KHz(0.5dB loss), @467KHz=-72dBc, 1dB ripple in passband, NF<=35dB, Gain<=10dB.
    I used 8-order ChebyshevI LPF and simulation results shows it met the above specs except NF. The NF of my circuit is about 60dB. I did not know how to reduce it.
