eric
I would like to use an arbitrary wave function as the input stimulus in my Spectre simulation (analog circuit). Usually when we run a Spectre simulation, we could use the standard stimulus such as Vsin, Vpulse etc from the analogLib. What if I need an arbitrary wave function as the stimulus, for example, exponentially increased sine wave? I guess this can be done thru CDF. Is there an easier way? Or are there any 3rd party component lib available? thank you so much! Eric p.s.: Which cdsdoc manual should I look into to find out the syntax for the stimulus file? Any examples? Thanks againi!
