Jul 20th, 2024, 3:25pm
SNR ,THD simulation (Read 8483 times)
neurocat
SNR ,THD simulation
Mar 17th, 2005, 1:48am
Smiley Smiley
hi
   how to simulate the SNR and THD of a class AB  Power amplifier. would u please give me some advices.
thanks a lot
benis
Guest
Re: SNR ,THD simulation
Reply #1 - Mar 24th, 2005, 2:20pm
to have an estimatin of your THD make a dft of your output to see how high are your armonic frequencies.
  IP Logged
James
snowfiled
Reply #2 - Mar 24th, 2005, 5:33pm
Then how to see the SNR result?
James
analogic
Reply #3 - Mar 25th, 2005, 11:58am
what i did is use the "prints" in Cadence calculator to export the spectrum points, then use Matlab to calculate SNR
gsuarez
Reply #4 - Mar 26th, 2005, 7:08am
Check this site and this pdf. Remeber if using Matlab that log base 10 is log10. I don't know much about amplifier characterization but in ADCs you need to have a coherent signal at the input with respect to the number of samples you measure at the output. If the coherent sampling condition is no met, you will have spectral leakage.
http://moon.pr.erau.edu/~lyallj/ee412/sinad_exp.html
http://www.strategic-test.com/support/download/uf_an-02_measuring%20dynamic%20sp...
If you need more about coherent sampling then go to http://www.maxim-ic.com and check for their application notes, they are really good.
George
Reply #5 - Mar 26th, 2005, 6:13pm
Neurocat,
   If the input is a sine wave, one alternative would
be to use the Spectre fourier component to calculate
the THD. In general the fourier component is very
accuracte and simplifies the THD measurement. The
only limitations are that it doesn't work for sampled
data applications, that is, for ADCs. In addition, you
need to be careful about calculating SNR from a dft.
The issue is that normally transient analysis does not
include device noise unless you specifically add[using behavioral models] so the noise floor of the spectrum
is set by the numerical noise in the simulation.
  If you do want to calculate SNR from the large signal
performance, a reasonable goal since this circuit is a
class-AB amplifier, try transient noise analysis. Don't
forgot to subtract the numerical noise floor from the
original spectrum(by RSS).
  BTW, as a thought experiment if you are using
Spectre, run your transient simulation using different
relref options: sigglobal, alllocal, pointlocal. You should
see that the amplitude of the fundamental and the
harmonics are constant, however, the amplitude of
the "noise" falls of significantly as the accuracy of the
simulation increases.
Reply #6 - Mar 29th, 2005, 8:33pm
Some other pointers on this topic:
a) use the strobeperiod option to transient, to ask spectre to solve at the points you're going to sample at in the fft - this removes the interpolation error you'd get when sampling. If you're using fft that is...
b) There's a THD function in the ADE calculator's special functions. This does an fft and then calculates the ratio of the first harmonic (I think this is controllable) to the other harmonics.
c) spectre now has a transient noise analysis, BTW, from MMSIM60 onwards. As with all transient noise analyses you have to be careful to average the noise over a long enough period of time (you do have control over the maximum noise bandwidth, which in turn sets the maximum timestep within the transient). It's another way to look at noise in non-periodic systems if the RF analyses aren't appropriate, and also to look at circuits with a nonlinear response to the noise.
