Aug 21st, 2024, 2:17am
Analysing waveforms using spectre. (Read 2684 times)
kamesh
Guest
Mar 22nd, 2005, 11:57am
Dear all,
  I have a circuit and I simulate it using Affirma Analog Circuit Design Environment. I get a wave form window with Voltage(V) on the Y axis and Time(t) on the X-axis. Now what i want is to export this data to a file like thing on which i can make further operations. A file which may contain data of Time and Voltage values. Any one can throw some light on this and tell me how I can go about this.
Thanks and Regards,
Kamesh.
P.S: I tried posting the same question in comp.cad.cadence. But unfortunately no one replied  :-[. Think there is some problem with google groups.
  IP Logged
Eugene
Re: Analysing waveforms using spectre.
Reply #1 - Mar 22nd, 2005, 4:11pm
If I understood your question, you have two options:
1. Use "printvs" in the waveform calculator to dump the data to a file. This becomes cumbersome if you have a large number of points because the waverform calculator will assume you did not really want to store so many points and ask that you use the command line.
2. Insert a VerilogA block that strobes and records the data of interest. I've used this many times. It works great as long as you are doing a Spectre transient analysis.
kamesh419
Reply #2 - Mar 23rd, 2005, 8:32am
Thank you very much Eugene, it really helped me..
Bye,
kamesh.
Truth lies everywhere and partially even with the error.
