Jul 20th, 2024, 3:17pm
suprresion of cadence simulation warnings (Read 4209 times)
benis
Guest
Mar 26th, 2005, 3:00pm
is there any option for not printing the warnings during a transiest let's say simulation at cadence analog environment?
  IP Logged
Re: suprresion of cadence simulation warnings
Reply #1 - Mar 27th, 2005, 10:21pm
On Simulator->Options->Analog you could set warn to no, or you could set maxwarnstologfile to 0. What kind of warnings are they? They may be important...
Sid
Reply #2 - Apr 19th, 2005, 8:48am
I actually want to get rid of Spectre (automatically) supressing warnings after the first few. I want to ensure I see all the warnings and then decide if they are harmful or not.
I see two parameters, maxwarn and maxwarntologfile. Which one should I set? or both? I think I will increase them to a large value like 1000.
Also, do you know the commands I can use to set these in the .cdsenv instead of doing it graphically everytime I start a simulation?
Sid
Reply #3 - Apr 20th, 2005, 10:09pm
Sid,
maxwarntologfile controls (as the name suggests) the warnings in the log file. maxwarn controls the warnings to the screen.
In ADE, when you look at the output file, that's a log file. So it would be the log file one you want.
The .cdsenv settings are:
spectre.opts    maxwarnstologfile	 string  "1000"
spectre.opts    maxwarns	  string  "1000"
