Yes. I use Assura UI. I have no where to find the parameter named "joinNets". Actually I only need it to work at the top level. I'd hate to launch Assura from command line.
![Sad Sad](https://designers-guide.org/forum/Templates/Forum/default/sad.gif)
[quote author=Paul link=1108323345/0#1 date=1108329262]Hi Stephen,
in Assura you can use joinNets("
netname") to virtually connect nets with the same name. You can select whether this has to be done on the schematic and/or layout side. joinPins works only on pins (and I believe only at the top level of your hierarchy). Do you use Assura on the command line or the Assura GUI? In the second case it may be a little tricky to find.
Also note the existence of the news group comp.cad.cadence (you can find it on Google groups for example), where you can find answers to many questions on Cadence tools.
Hope this helps
Paul [/quote]
