Stephen,
Diva normally extracts contacts rather excessively, (many resistors per contact) unless you do things in the rules file to minimise this (usually tricks like oversizing and undersizing the contacts to merge them all together). Perhaps this is happening, and then the resulting via array is ending up a smaller resistance than the minimum specified in the rule file, and hence they are being filtered?
It's bound to be dependent on the specifics of the rule file rather than a generic tool issue (at least that's what I expect).
