May 18th, 2024, 1:10am
copying questions in Virtuoso layout tool (Read 7912 times)
CDR
Aug 24th, 2004, 2:58pm
In Virtuoso layout, if I try to move and make the layout cell at "sideway" position, it works fine.But sometimes, the function menu doesn't apper when I press "m" and F3, but after I logoff the cadence,restart,then it will work.How could I solve this problem?
Re: copying questions in Virtuoso layout tool
Reply #1 - Aug 24th, 2004, 9:45pm
That sounds very odd. Repeated F3 hits should toggle the option form.
I can't remember whether this is Virtuoso or Composer, but there's an icon on the left side which does the same thing - brings up the command options form. Also, double-clicking the middle mouse button is another bindkey often set to do this.
Do you use the num lock key? I'm wondering whether it is an old Sun bug where hitting num lock prevents some bindkeys from working properly (there's a Solaris patch for this, but you can work around it by turning num lock off and then hitting enter in the CIW)
Reply #2 - Aug 26th, 2004, 7:21am
Are you sure that the layout editor window is active when you press "m" and F3?
Best regards,
Yawei
CDR
Reply #3 - Aug 26th, 2004, 4:57pm
I am using Sun Solaris.This "copy" problem in Virtuoso happens often.Sometimes the only solution is to restart the cadence and everything will be fine again.
Reply #4 - Aug 26th, 2004, 9:39pm
CDR,
If you don't answer the questions asked to you by people trying to help you, then you're not going to get much help, are you?
Both Yawei and I have asked you questions, but you didn't answer either of us in your last reply - just re-stated the problem.
CDR
Reply #5 - Aug 27th, 2004, 8:21am
Sorry,Yawei and Andrew,
I only saw both of your mail today.I coudln't login yesterday for a while,so I only looked at the last reply.
Firstly I don't know whether my workstation has num lock key,how to detect that?
Yes,there is menu on the left side of the Virtuoso,but I didn't find any prolbems at least now.Formerly I always use "m",and then there will be pop-up.
Yawei,yes,when I press "m" and "F3",my layout window is active.
It seems that sometimes when I start a large simulation and do the layout at the same time, there will be some error happening,like the pop up window don't appear when I try to copy or move.
Reply #6 - Aug 31st, 2004, 5:46am
[quote author=CDR  link=1093384680/0#5 date=1093620086]
[/quote]
Er, try looking at the keyboard and seeing if one of the keys is labelled "Num Lock"  ???
graywang
Reply #7 - Oct 18th, 2006, 6:11pm
CDR,
If you would met this issue next time.you could try to change the Options of ICFB.
Change "Nest Limit 5" to "Nest Limit 20".The issue may be disppear.That's my own point.
FYI.
thanks
