Well, if it is an IC process, 15V is absolutely not typical - unless you're using some high voltage process. The smaller the geometry, the smaller the supply voltage (as a rule of thumb). A few years back, 5V supplies were commonplace. Then 3V, and for 0.18u and below, 1.8V (although often these type of processes support analog transistors which can be operated at 3V, whereas the digital circuits operate at the lower voltage to reduce power).
From memory of designs I did in the past, 5V supplies were common for (say) 3u to 1u technologies; 3V for 1u to 0.25u; 1.8V below that. That's just a rough idea - actual processes will vary considerably.
So 15V is definitely not typical of most processes!
Even if you have opamps at the board level, I don't think 15V would be typical.
