You should contact customer support. However, as a first step, you might want to try seeing if you're using the latest version - you didn't mention what version you're using.
I'd suggest trying it in the latest IUS54 ISR to see if that fixes it, then contact customer support if it doesn't.
Unfortunately the error is fairly non-specific, and so it's hard to debug from the message alone.
