Apr 29th, 2024, 5:19am
ncverilog simulation (Read 2287 times)
senthil
Apr 18th, 2005, 12:58am
HI
While simulating the ARM core   using the ncverilog simulator on a HPUX machine  , I am getting this error
ncsim: *internal* (rts_seghandler - SIGSEGV unexpected violation pc=0xc3b26b68 addr=0x2 )
While performing the same simulation on ther OS such as Linux and Solaris ,the above mentioned error is not occuring.
Kindly help me regarding this ...
Regards ,
Senthilvelan
Re: ncverilog simulation
Reply #1 - Apr 18th, 2005, 4:46am
You should contact customer support. However, as a first step, you might want to try seeing if you're using the latest version - you didn't mention what version you're using.
I'd suggest trying it in the latest IUS54 ISR to see if that fixes it, then contact customer support if it doesn't.
Unfortunately the error is fairly non-specific, and so it's hard to debug from the message alone.
