Aug 22nd, 2024, 12:37am
Ken's THA in veriloga (Read 10775 times)
Sid
Apr 03rd, 2005, 10:43pm
 I am trying to use Ken's veriloga THA (for use with SpectreRF without hidden-states). I copied the text file from:
http://www.designers-guide.org/VerilogAMS/rf-models/sh/sh.va
and created a veriloga view in cadence for a cell called sh. Then I created a symbol for sh with pins Pin, Nin, Pout and Nout.
I have never used veriloga before and do not particularly understand it. When I try to simulate a schematic with the symbol for sh instantiated in it, I get an error from Spectre that it cannot find a view to decend into sh. I made sure veriloga is listed in my "view-list". What should I do to get this to work? Do I have to "compile" the veriloga code (a wild guess)?
Also, for this SHA what do Pin, Pout, Nin and Nout represent? I was expecting the ports to be more like vin, vout and clk...
Any help will be appreciated.
Sid
Re: Ken's THA in veriloga
Reply #1 - Apr 3rd, 2005, 11:45pm
Sid,
 Have you checked the name of the module in the veriloga code? The
name of the module should be sh. Also, what is the order of the
cell views in the view list? Is veriloga before symbol in the list?
Also, are you using the hierarchy editor? It is meant this type of
application.
Reply #2 - Apr 4th, 2005, 7:46am
Pin and Nin are the positive and negative input terminals. Pout and Pout are the output terminals. Vin = V(Pin,Nin) and Vout = V(Pout,Nout). If you want single sided input and output, connect Nin and Nout to ground.
There is no external clock. It samples all by itself without an externally applied clock every "period" seconds. If you want an external clock, you will need to modify the model.
Reply #3 - Apr 4th, 2005, 8:11am
If you want an external clock and do not need the ability to run the model in SpectreRF, you can use one of the models given in http://www.designers-guide.org/VerilogAMS/functional-blocks/sh/sh.va.
Sid
Reply #4 - Apr 5th, 2005, 4:48pm
Sheldon,
     Thanks for your response. My view-list is:
"spectre cmos_sch cmos.sch schematic veriloga ahdl"
So it should be able to pick up veriloga. Not sure why it is failing. Also, my module name and the cell-view name are the same (called SHA_ideal).  Any other thing to look for or try?
   I will see if hierarchy editor helps me. I have never used it before so it may take me a while to figure it out.
Sid
Ken,
   Thanks for the explanation on the THA block functionality. Hopefully I will get it to run in Cadence soon.
Sid
Reply #5 - Apr 5th, 2005, 10:41pm
You say the cell-view name is "SAH_ideal". Do you mean
that the view name is "SAH_ideal", or is the cellName "SAH_ideal", and the viewName "veriloga"? The latter is what you need.
Sid
Reply #6 - Apr 6th, 2005, 12:16am
Andrew,
Thanks for the reply. My cell-name (and "module" name in the veriloga code) is "SHA_ideal" (instead of the "sh" that Ken used in his code). My view-name is "veriloga". So, I think I have that correct.
Sid
Reply #7 - Apr 7th, 2005, 1:20pm
Did you get any errors when you entered the veriloga view? Just to make sure, edit the cellView and add a blank line (say).
Also, do you have any other views under that cell with any of the earlier viewNames in the switch list you list?
Can you paste the exact error message given in the CIW?
Sid
Reply #8 - Apr 13th, 2005, 8:49pm
Hi Andrew,
I entered the veriloga view in a text-editor (vi), so I am not sure if there is an error in it. The code is pasted below at the end of the email - identical to Ken's THA.
The exact error I got from Cadence in the CIW is:
Begin Incremental Netlisting Apr 13 23:24:48 2005
ERROR: Netlister: unable to descend into any of the views defined in the view list: "veriloga spectre cmos_sch cmos.sch schematic ahdl" for instance I1 in cell SHA_ideal_test.
Either add one of these views to: Library: boosted_swit_mar_05 Cell: SHA_ideal or modify the view list to contain an existing view.
End netlisting Apr 13 23:24:48 2005
I only have 2-views for "SHA_ideal" - veriloga and symbol.
Any help would be appreciated.
Sid
// VerilogA for boosted_swit_mar_05, SHA_ideal, veriloga
// Periodic Track & Hold
// Works with SpectreRF (has no hidden state)
// Almost ideal ...
//    Has buffered input and output (infinite input Z, zero out Z)
//    Exhibits no offset or distortion errors
//    Only nonideality is finite aperture time and very small amount of droop
`include "constants.h"
`include "discipline.h"
module SHA_ideal (Pout, Nout, Pin, Nin);
electrical Pin, Nin, Pout, Nout;
input Pin, Nin;
output Pout, Nout;
parameter real period=1 from (0:inf);
parameter real tdelay=0 from [0:inf);
parameter real aperture=period/100 from (0:period/2);
parameter real tc=aperture/10 from (0:aperture);
integer n;
real tstart, tstop;
electrical hold;
   analog begin
// Determine the point where the aperture begins;
       n = ($abstime - tdelay + aperture) / period + 0.5;
       tstart = n*period + tdelay - aperture;
       @(timer(tstart));
// Determine the time where the aperture ends;
       n = ($abstime - tdelay) / period + 0.0;
       tstop = n*period + tdelay;
       @(timer(tstop));
// Implement switch with effective series resistence of 1 Ohm
       if (($abstime > tstop - aperture) && ($abstime <= tstop))
           I(hold) <+ V(hold) - V(Pin, Nin);
       else
           I(hold) <+ 1.0e-12 * V(hold);
// Implement capacitor with an effective capacitance of tc
       I(hold) <+ tc * ddt(V(hold));
// Buffer output
       V(Pout, Nout) <+ V(hold);
// Control time step tightly during aperture and loosely otherwise
       if (($abstime >= tstop - aperture) && ($abstime < tstop)) begin
           $bound_step(tc);
       end else begin
           $bound_step(period/5);
Reply #9 - Apr 13th, 2005, 10:08pm
You say you entered it in a text editor - do you mean from the UNIX prompt, or do you mean you did it by opening the cellView from the library manager in edit mode, or from the File->Open->Cellview form in the CIW?
You need to edit it this way, save, and exit the editor, then it will go ahead an parse the code to ensure it is syntactically correct, and generate other files needed in the cellView directory. Messages should appear in the CIW when you do this (what version are you using by the way - type "icfb -W"?).
Perhaps you can go to the directory where your library is located, and do:
ls -l boosted_swit_mar_05/SHA_ideal/veriloga
and post what it says?
I've not had a chance to validate the code you posted (may be able to do this later), but I'm concerned that perhaps you're not editing the cellView properly?
Sid
Reply #10 - Apr 14th, 2005, 10:21am
Hi Andrew,
Thanks you so much for the help. You were correct - I was not editing the code using Cadence's default text editor (in my case "vi"). I prefer nedit and hence, once the "veriloga" basic text file was created by Cadence, I went ahead and closed the vi window and did all the editing (like cutting and pasting Ken's code) in nedit (opened through the Linux terminal).
As per your suggession I saved the code again by opening the veriloga code from within Cadence (in vi) and it compiled correctly and the simulation worked.
Do you know how I could change my default Cadence text editor to nedit (instead of vi)? This is not important, but could make my job easier.
Thanks again for all the help.
Sid
Reply #11 - Apr 15th, 2005, 6:45am
Hi Sid,
Put this in the CIW, or in your .cdsinit file:
editor="nedit"
