Aug 21st, 2024, 6:20pm
Cgg vs Vgs for MOSFETs (Read 1011 times)
cricket_fan
Guest
Apr 05th, 2005, 10:57am
Hi
I am trying to look at the Cgg of a mosfet device. I am using Cadence dsign environment for this.
When I do a dc sweep of the gate under various drain biases (linear/saturation) , how can I plot Cgg against Vgs using the calculator.
I had done this before but using a raw netlist file and running spectre standalone (without Cadence) and it was possible to obtain Cgg as an output parameter.
Any pointers/suggestions would be helpful.
thanks
MMN
  IP Logged
Re: Cgg vs Vgs for MOSFETs
Reply #1 - Apr 7th, 2005, 1:25pm
This has been answered several times before in this forum, albeit in a slightly different form.
http://www.designers-guide.org/Forum/?board=rfdesign;action=display;num=10850506...
which in turn has a reference to another similar answer.
nus_lin
Reply #2 - Apr 8th, 2005, 12:46am
poor andrew, you have to answer the same question again and again, Grin
hi, do you know the meaning of cgg, cgd, cgs, csg in the bsim3 model? why they are sometimes negative? if i want to manually find out the capacitance at one node, what should i do from the op point?
Reply #3 - Apr 8th, 2005, 6:13am
OK, prepare to be sympathetic to me again. This one I've answered at least twice:
http://www.designers-guide.org/Forum/?board=analog_design;action=display;num=108...
http://www.designers-guide.org/Forum/?board=semi;action=display;num=1053460340;s...
See that little magnifying glass, with Search written next to it at the top of the page... well, guess what it's for?
(a search for "bsim3v3 negative capacitor" found the two links above).
cricket_fan
Guest
Reply #4 - Apr 8th, 2005, 12:29pm
Ignore previous message I found out how to get all parms.  of individual MOS instances.
thanks
  IP Logged
