Aug 21st, 2024, 4:20pm
how to plot intrinsic frequency ? (Read 4386 times)
nus_lin
Apr 07th, 2005, 9:02am
Dear andew and ken,
last time i ask how to plot gm over I, and what you told me did work. however, plotting intrinsic frequency over I is much more complex. can you spend some time to drop down your solution? i am using analog artist with simulator=spectre.
btw, may i save an expression base on a transistor's op point? say gm/cgs?
Re: how to plot intrinsic frequency ?
Reply #1 - Apr 7th, 2005, 1:12pm
I don't know exactly what you mean by intrinsic frequency (please elaborate), but answering your second question might answer it for you.
You don't need to save an expression in spectre, but if you do:
save m1:gm m1:cgs
or just:
save m1
(which will save all operating point data for a specific transistor), you can then compute gm/cgs in the calculator. If you can plot gm versus I, and cgs versus I, then in the calculator dividing the two will give gm/cgs versus I.
Whatever calculation you need to do to compute intrinsic frequency, can be done in this way.
James
snowfiled
Reply #2 - Apr 7th, 2005, 6:38pm
Do you mean intrinsic frequency "gm*ro"?
James
nus_lin
Reply #3 - Apr 7th, 2005, 7:13pm
[quote author=James  link=1112889742/0#2 date=1112924296]Do you mean intrinsic frequency "gm*ro"? [/quote]
this is intrinsic gain.
James
snowfiled
Reply #4 - Apr 7th, 2005, 7:22pm
Then what do you mean intrinsic frequency?
James
nus_lin
Reply #5 - Apr 8th, 2005, 12:41am
ideally, it is the frequency that the gain of input current equals to output current.
