jimmy
We want to setup the distribution simulation for our cadence (the version is 5.1.41). The following is what our computer support wrote to me. It seems that might be a conflication between our system job balancing tool and cadence's internal LBS tool. Can you please give me some advice on this.
thank you so much, jimmy ---------------------------------------------------------------------- swarm used to have LSF but we dropped it due to cost in favor of a free application to do the distribution of jobs.
if we can do this only using their LBS software (load balancing), but it should work on swarm.
my fear though is that we're going to have conflicts between users. swarm currently is using one set of job scheduling and balancing tools, and cadence wants a completely separate one. it's almost like you guys would need to work things out such that when you need machines, the other folks couldn't use a predefined set of machines.
