danda821
I am using Cadence icfb under unix system, using a DELL LCD monitor (1600x1200). When I set the color depth (using fbconfig command) to be 24, the speed of Cadence is very slow (esp. when doing the layout). When I set the color depth to be 8, everything is fine. But the color of the monitor is not good, esp. when using the web browser. It seems like Cadence can only work under 8 depth?
Thanks.
