Apr 27th, 2024, 2:27pm
parsing of ahdl failed - cadence model writer (Read 3369 times)
trond
Glasgow, Scotland
Apr 18th, 2005, 2:35am
When using the Cadence Model Writer 2.28 and generating the code it always gives me the following error: "Parsing of ahdl failed". However, when I write my own code or use code from this site everything works fine.
Any ideas why the model writer does not work properly?
Cheers,
svensl
Re: parsing of ahdl failed - cadence model writer
Reply #1 - Jun 6th, 2005, 6:42am
I've never used model writer, but ... don't you get any more information from the parser about what failed in particular?  Have you looked at the code to see if you can spot any obvious problems?  Are you using Verilog-A or SpectreHDL?
trond
Glasgow, Scotland
Reply #2 - Jun 8th, 2005, 7:19am
The problem was that the modelwriter could not find the disciplines and constants .vams and .h files.  Once I had copied them into my working directory everything worked fine.
