Jul 19th, 2024, 11:21pm
error correction circuit for 1.5bit/stage pipeline (Read 6287 times)
ericjohnson
May 26th, 2005, 10:10pm
Can someone please provide some good reference on how to design error correction circuit for 1.5b/stage pipelined ADC? If detailed circuit topology/schematic can be provided, that'll be greatly appreciated!
Re: error correction circuit for 1.5bit/stage pipe
Reply #1 - May 30th, 2005, 10:56pm
Ericjohnson,
The earliest paper presented the 1.5bit/stage algorithm (RSD) is by B. Ginetti, P. Jespers, "A 1.5 Ms/s 8-bit Pipelined RSD A/D Converter," in European Solid-State Circuits Conference Digest of Technical Papers, pp. 137-140, Sep. 1990. But I havn't that paper since only ESSCIRC papers after 1996 are availabe on its website. But I have another paper by G. Ginetti, et al., A CMOS 13-b cyclic RSD A/D converter, JSSC, July, 1992. I hope it will be helpful for you.
Best regards,
Yawei
ericjohnson
Reply #2 - May 31st, 2005, 8:12am
Thank you , Yawei. I will read the paper.
Paul
Switzerland
Reply #3 - Jun 1st, 2005, 12:52pm
Eric
you can also try to find Jesper's book. I find it well written, but sometimes too concise on the details:
http://www.oup.co.uk/isbn/0-19-856446-5
Anyway this scheme has been used by many people, so you should be able to find many papers on it. It seems to me it's just about addition of output codes, but make sure to use the right format and offset. There's also the following Maxim appnote:
http://maximic.com/appnotes.cfm/appnote_number/1023
although, I dislike some statements like "The implication is that none of the flash ADCs in Figure 1 has to be as accurate as the entire ADC." This may be true for the gain error, but the non-linearity of any stage directly affects the overall non-linearity directly. So be careful...
Paul
ericjohnson
Reply #4 - Jun 4th, 2005, 11:24am
Thank you, Paul. If I understand correctly, the digital error correction part is just a simple adder, right?
Reply #5 - Jun 6th, 2005, 9:51pm
Ericjohnson,
You are right.
Yawei
