Aug 24th, 2024, 2:13pm
reference to Vth in macromodeling (Read 3677 times)
hossein_ml
May 27th, 2005, 1:43pm
I have been trying to use the calculated value of Vth in Spectre DC analysis for my macromodels. Since in my macromodel, Vgs is sweeped, Vth will also be changed. Therefore, I need to use the real-time value of Vth in each step of parametric simulation in order to get accurate results. Anyone knows how I can reference to Vth parameter that is calculated by Spectre DC Analysis in the schematic when defining a value of say a resistor. I need to define this value based on accurate value of Vth. Is it possible at all?
Re: reference to Vth in macromodeling
Reply #1 - May 31st, 2005, 10:41am
I initially thought you could do this with a bsource, something like:
model nch mos1 type=n vto=1 kp=16u gamma=1.3 lambda=0.01 \
    phi=0.7 pb=0.80 mj=0.5 mjsw=0.3 cgbo=200p cgso=350p cgdo=350p \
    cj=300u cjsw=500p ld=0.1u tox=80n \
    af=1 kf=3.1e-24
m1 (drain gate 0 0) nch w=20u l=0.8u
vgs (gate 0) vsource dc=1
vds (drain 0) vsource dc=1
rmeas (rop 0) bsource r=m1:vth*1000
imeas (rop 0) isource i=1u
save m1:ids rop
parameters start=0 stop=5 step=20m gsv=1
vgssweep sweep dev=vgs param=dc start=0.6 stop=2.0 step=0.2 {
    dcAnalysis dc dev=vds start=start stop=stop step=step
(bsource could have been "resistor" in the above example).
However, this doesn't work. I then remembered that there is:
   PCR: 568208
 Title: Allow passing device operating point to bsource
to get this to work.
So it's not possible right now (assuming I've understood the question properly!)
aamar
Reply #2 - May 31st, 2005, 12:27pm
Is the bsource, a generic dependent source? which I can use for example to define a current source, which is dependent on both current and voltage at the same time?
and if so, is there a symbol for it ? or must I edit the spectre netlist manually?
Reply #3 - Jun 1st, 2005, 1:20am
bsource is a generic dependent component, which can be a resistor, capacitor, inductor, voltage source or current source - dependent on expressions of voltages and currents. See spectre -h bsource for more details.
There is no component for it in analogLib - mainly because the expressions would confuse ADE - it tends to think that such expressions include design variables where you're actually referring to voltages at nodes in the design (say).
Mostly bsource gets used for device models - so you can create a subckt (or inline subckt) model and then include this as a model file, and have a corresponding symbol for that in DFII.
