Aug 23rd, 2024, 4:27pm
how to record the zero-crossing timing points (Read 1838 times)
jfyan
Guest
May 29th, 2005, 6:55am
hi all:
how can i record the zero-crossing timing points in spectre to a voltage wave?
i mean, i want to put down the wave's every zero-crossing times in transient analysis.
thanks in advance.
  IP Logged
Re: how to record the zero-crossing timing points
Reply #1 - May 31st, 2005, 10:52am
In OCEAN, you can do:
selectResult('tran)
crosses=cross(v("/out") 0.0 0 'either)
The 0.0 is the threshold level, 0 tells it to output all crossings,
and 'either specifies both rising and falling.
The result will be a list.
See the OCEAN documentation for more details on what to do with the result!
